wat bhp??
Old Jul 23, 2006 | 07:53 PM
craigb's Avatar
Default wat bhp??
B16A2 1.6 TURBO CURRENTLY RUNNING 260 BHP AT 7 PSI BOOST ON STANDARD INTERNALS
CHROMALLOY ULTRA LIGHTWEIGHT FLYWHEEL
550 CC INJECTORS
BLITZ AIRFILTER
PEAKBOOST STAINLESS STEEL EQUAL LENGHT EXHAUST MANIFOLD MADE OF 321 8 GAUGE STAINLESS STEEL
GARRET T3/TO4E TURBOCHARGER
TIAL 38MM EXTERNAL WASTEGATE AND SCREAMER PIPE
PEAKBOOST GARRET CORE 24X6X3.5 INTERCOOLER (2.5" INLET AND OUTLET)
TIAL BLOW OFF VALVE
TIG WELDED 2.5" CHARGE PIPING
3 INCH DOWNPIPE
UBERDATA CHIPPED ECU
WALBRO UP RATED FUEL PUMP
ACT UPRATED CLUTCH PLATE AND PRESSURE PLATE
will be fitting this stuff below next week wat ye reckon
greddy head gasket,all new bearings etc
1.8 integra block b18c been overbored .25 i have wiseco pistons to match and eagle rods
act extreme pressure plate and clutch plate an eagle block guard i have skunk 2 adjustable front camber arms and rear omni adjustable camber arms oh and another turbo manifold
and i have a 14.5 psi spring or 1 bar
Old Jul 25, 2006 | 12:23 PM
craigb's Avatar
Default RE: wat bhp??
im hoping for around 350 360whp with this set up wat ye reckon.
Old Jul 26, 2006 | 12:48 PM
larsenracing's Avatar
Are you sure you are running 260BHP, That sounds like a quit a bit for 7PSI and stock internals and that little of mods. But if that is where you are at now you should have not to much problem getting there you will have to up the boost a quiet a bit but do you have any ignition upgrades and a cat back exhauts because if not you will have a hell of a time getting there. If you dont have a wide band O2 i would sigguest getting one just so you can keep better track of your cars runnings. Good luck to ya.
Old Jul 26, 2006 | 03:10 PM
Nail I3unny's Avatar
i dont think so. generally speaking, a turbo D on that boost can make over 200 at the wheels. general consensus is a honda engine can handle up to twice the power it is stock with. stock the b16 puts around 145 to the ground, so conciveably you could hit 260 in moderate boost.
Old Jul 26, 2006 | 05:04 PM
craigb's Avatar
ORIGINAL: larsenracing
no bud not realy, thats the spec sheet off the fella i bought if off. if i was to guess id say around the 230 at the moment. straight through 2.5" exhaust bud.planning on running 1 bar with the new (built block)????
Simonballard87
May 24, 2005 11:44 AM
djglovehead
Apr 14, 2005 07:33 AM
djglovehead
Apr 12, 2005 10:05 AM
kingfu
Sep 19, 2004 06:06 AM
