what exactly do you need to turbo
Old Jan 7, 2007 | 12:38 AM
bawm's Avatar
Default what exactly do you need to turbo
i have a completely stock 00 civic ex coupe
can someone tell me what else i need to have a complete turbo setup
turbo
manifold
wastegate
oil line kit
intercooler
intercooler piping
down pipe
BOV
Old Jan 7, 2007 | 12:58 AM
drbyers's Avatar
Default RE: what exactly do you need to turbo
turbos/superchargers require MORE fuel, MORE air, and MORE engine control.
that said, you need to address fuel injectors and better engine management, as well as block sleeving/piston swapping/etc. if the psi require it.
you need to do more research before attempting a turbo setup.
Old Jan 7, 2007 | 09:36 AM
What you "need" is not nearly as important as what you "need to do"
What you need to do, is research
Old Jan 7, 2007 | 11:58 AM
riceburner700's Avatar
TUNE TUNE TUNE would be your main concern
Old Jan 7, 2007 | 01:48 PM
ScoobyAddict14's Avatar
formerly aryiman98civic
https://www.hondacivicforum.com/m_196090/tm.htm
there is a list of things you need, but you will later figure out you need a lot of odds and ends stuff people dont post up most of the time.
Old Jan 7, 2007 | 10:47 PM
bawm's Avatar
ive done alot of research and ive alrdy lookd at petes grocery list
do i need new
injectors
fuel pump
water pump
fpr
fuel rail
any electronics
Old Jan 8, 2007 | 09:13 AM
INJENalltheway's Avatar
Not enough apparently...
Old Jan 9, 2007 | 06:58 AM
dfdon's Avatar
what are your goals for your car?
Old Jan 13, 2007 | 01:53 AM
bawm's Avatar
i want to have 300whp eventually
is this a good setup and do i need anything else
t3/t4 turbo not sure wich trim/ar yet
mani not sure wich
ic + piping not sure which
tial bov
tial wastegate if turb isnt internal btw wich turbos are interally gated
rc 550 injectors
walbro 255 lph hp fuel pump
NGK blue wires
NGK plugs
3" downpipe not sure wich
3" exhaust not sure wich
muffler
chippd p28 ecu
obd2-obd1 harness
boost gauge
Old Jan 13, 2007 | 10:50 AM
Mr Mobsta Man's Avatar
If you want to make 300hp u need to rebuild your internals and you will also need to use an external wastegate.
bgrlflare
Aug 27, 2007 07:30 AM
akskimaster
Apr 17, 2006 04:48 PM
alarum
Mar 29, 2006 12:34 PM
2000 LoW reD Si
Feb 13, 2006 12:13 PM
sexyexy99
Jul 6, 2004 04:57 AM
