Why would my radiator blow at idle?
Old Mar 6, 2009 | 08:53 AM
  #21
V8DIET's Avatar
I thought the pre-mixed stuff was only 50/50. And you can buy a gallon of distilled water at the store for like $1.00 and you won't need more than that. I should have been more clear on what water to mix the coolant with. +1 on not using tap water.
Old Mar 6, 2009 | 09:24 AM
  #22
I definitely know that both 50:50 and 70:30 premixed coolant are commercially available. There may be other premixed concentrations available as well. As you say, it's also possible to purchase distilled water and prepare your favorite coolant concentrations at home. Nonetheless, there are several reasons that I don't recommend this procedure to most people. Mixing coolant at home requires not only a separate purchase of distilled water, which incidentally increases the expense, it also requires one to have an accurate mixing vessel. In addition, the mixing procedure is subject to user error (simple math is not simple for everyone). In summary, I recommend that people just purchase premixed coolant in order to reduce both hassle and expense.
Old Mar 6, 2009 | 09:25 AM
  #23
StifflersMom's Avatar
Cat Fuсker
Ron, I disagree with buying premixed. It's overpriced and you have no idea if it's truly the mix that it's stated at. If I lived in a colder(warmer) climate I would definitely worry about it being the correct mix. Same goes for windshield washer fluid.
Old Mar 6, 2009 | 09:28 AM
  #24
Gene, I have an enormous respect for your opinion (even when you are sarcastic), but I think we need to agree to disagree on this point.
Old Mar 6, 2009 | 09:38 AM
  #25
Cat Fuсker
Well, I guess we'll just have to disagree
Old Mar 6, 2009 | 09:45 AM
  #26
By the way, you and StifflersMom (sig pic) look alike, aside from the haircut. Also, your daughter is a beauty. She must take after her Mom.
Old Mar 6, 2009 | 10:00 AM
  #27
Cat Fuсker
huh? Where did you see me?
Old Mar 6, 2009 | 11:25 AM
  #28
FlipHKD720's Avatar
bad cooling fan relay is what the shop diagnosed btw
Old Mar 6, 2009 | 11:28 AM
  #29
jprommel's Avatar
Angry Admin
continuing in the off topic direction rob that pic is not gene hes not that fugly
Old Mar 6, 2009 | 11:37 AM
  #30
Originally Posted by jprommel
...that pic is not gene hes not that fugly
Oh sure.
--Sorry Flip, your overheating problem became too boring so it was inevitable to stray off topic. By the way, with your Civic experience, why pay a shop to figure out a pretty simple problem like this for you?
