ZC turbo kits?
Hey all you knowledgeable turbo types. I'm looking for a turbo kit for a Blacktop ZC motor, or any kit for a USDM equivalent that will work on a ZC. Know of any companies? Please don't hesitate to let me know.
dont the sohc exhaust manifolds bolt up to the zc motors? not sure, but i think i read that somewhere. if so, then it would be easy to get a mani for a sohc and make it work. even an old stock hf manifold will work with an adapter plate for a turbo to bolt to the bottom
You do not need to go out and buy some expensive kit, you can go down to your local wrecking yard and piece it all together. It does take some work but when your done you will be happy. A good site to learn what to do is www.homemadeturbo.com read all the forums there and get familiar with what you want to do with your car
Good Luck
Good Luck
