Private 'Wanted' Classifieds Looking for something? Tell us!
HELP! NTB lower control arms 1996 hatch.
Old Apr 28, 2009 | 03:28 AM
V8DIET's Avatar
Default HELP! NTB lower control arms 1996 hatch.
Like the title says, I need a set of lower control arms for a 1996 hatch . I was putting on the new setup and both of my lower strut bolts broke and i had to cut the bushing out. Any brand as long as it's brand name and they can be stock as long as they are mint. Must have all the bushings and if you have the lower strut bolts that would be awesome. Let me know I need these things yesterday.
Old Apr 28, 2009 | 07:44 AM
V8DIET's Avatar
Anybody??
Old May 7, 2009 | 08:30 AM
baker's Avatar
You need the bushings where the strut meets the lca? If so I have a complete set of never used Energy Suspensions, I probably have the bolts lying around as well.
Old May 7, 2009 | 10:35 AM
V8DIET's Avatar
I went ahead a bought a set of BLOX LCA's and new bolts from honda. Thanks tho. I may need those bolts tho if my toe links are going to be a PITA to take out and the bolts end up breaking on those too. I'll let you know.
Old Jan 6, 2010 | 03:21 PM
you do know you could have just had the old bushings pressed out and new ones pressed in right?
and with the suspension bolts its BEST to just go to HONDA and buy brand new bolts... jus tbe sure to use some antiseize all over the bolts threads and the shaft to prevent them from seizing in the future!
only bushings that cannt be replaced is the toe adjustment bracket. then you just replace the whole arm.
Jaboy
Jan 25, 2007 01:35 PM
JDM_THUG
Dec 1, 2006 07:46 AM
903door
May 21, 2006 01:26 PM
StifflersMom
May 23, 2005 12:51 AM
paul
Oct 4, 2004 07:05 PM
