17inch rims, upgrading from 15. question
Old Jan 30, 2006 | 08:23 PM
deadphishy's Avatar
Default 17inch rims, upgrading from 15. question
I was wondering, if there was anyway to keep my speedometer close to normal if i upgrade my rims from 15 inches to 17. My thoughts were i could get low profiles tires that would end up having the same Circumference as 15's with high profile tires. if not can it be done with 16's.
thanks
Deadphishy
Old Jan 30, 2006 | 09:20 PM
mill$civic's Avatar
Default RE: 17inch rims, upgrading from 15. question
hey, im not really sure about this but i dont think you really have to worry, it dosent tho it off that much that its a big deal, ..if it even if it throws it off at all
Old Jan 30, 2006 | 09:28 PM
Cutt's Avatar
I got 17s on right now and really can't tell a diff.
Old Jan 31, 2006 | 04:13 PM
Bino's Avatar
same here i got 17 and it not off that much. i get next to my friends that are running stock and it about the same so i say get them.
Old Jan 31, 2006 | 09:00 PM
deadphishy's Avatar
Where do you think i should get my rims and tires? I was thinking discount tire.
and what size tire do you think would look/work the best without any rub, or even getting close to any rub.
Old Feb 4, 2006 | 01:46 AM
NTX's Avatar
NTX
ORIGINAL: deadphishy
the tire size will change as the rim size changes, so your speedo will be fine.
Old Feb 4, 2006 | 07:56 AM
usmc2b2004's Avatar
First off my brother also a CX and he has 18's on it so thats really bout as big as you probably wont to go. He never has any rub problem. But yea Discount is not a bad way to go.
Old Feb 27, 2006 | 08:50 PM
KarTuneMan's Avatar
A 205/40/17 is 23.69 inches tall
A 205/50/15 is 23.36.....1/3 of an inch shorter.....a great fit!
Old Feb 17, 2007 | 01:33 AM
vansterdam's Avatar
Here's a good tire calculator that lets you compare tire sizes. You want to keep your tire size within 3% of stock height.
Old Feb 17, 2007 | 06:18 AM
mxs's Avatar
mxs
Yes
