19's on stock suspension?
make sure u talk to the people selling you them i am sure it all depends on what kind of drop u have and what series tires comes with it ....i will tell you though it takes longer to get up to speed and longer to brake and it also rubs when u do sharp turns or u turns. also depending on the drop on the back u might have to roll your inner fender wall or cut the lip off. ..ride quality is a lil more bumpier but not as bad as cheap ebay coilovers so make sure all the suspension is good..
ok jus saw stock setup u will probably rub over bounces since the stock spring is meant to travel more for a comfortable ride u might want to invest in some lowering springs they are meant to be stiffer and won't travel as much..
t0wards eternity
Nov 10, 2007 05:55 AM
FlipHKD720
26
Mar 26, 2007 11:39 AM
shadowSI
Oct 2, 2006 01:54 PM
Bostonhoodhop
Jul 20, 2006 10:42 PM
