2 inch drop on springs and stock shocks
I have searched and never got a real clear answer. If I just do a 2 inch drop all around just srpings on stock shocks will I need to get new shocks? if so I got some in mind. also do i need to purchase all 4 shocks or just 2...every place i se sells them for about 80 each and im trying to stay within my 300 budget.
I jusy want something for a DD and still have some good performance aspects. Thanks |
RE: 2 inch drop on springs and stock shocks
you should do all 4 shocks or your stock ones mit blow out. you sure you want to do a 2 inch drop i just did a 1.8 in the front and 1.5 in the back. and my car hit's the ground
ok cool. really!? wow and thats my concern. I have a body kit and really dont wann mess it up.. but 2 inches would fill the gap better...how big is your gap?
yeah u'll want to replace the shocks. easier and cheaper to just do it all at once. u'll need all 4.
Ok for 7thgens I heard ground control is good spring..
I have an offer for 100$ springs..dropzone..are they ok? and whats a good shock to get thats not freakin 80a piece..keep in mind my 300-350 limit please |
Ground Control makes coilovers and they use Eibach springs on them. their also quite a bit more expensive then ur run of the mill springs. dropzone's are junk, for an extra ~$100 u can get Tein S-Techs brand new. probably the cheapest decent shocks u'll find would be the Tokico blues or the KYB GR2's. parts are more expensive for ur generation so u may want to up ur budget a bit.
so what would you say would be a great DD setup..around ok lets say tops 600..perferable less tho
bump
If u have a kit on and its urr dd i would go with tein s tech's and tokico struts....thats gonna run u prolly about 500 on ebay just make sure there the real ones and not fake...but keep in mind u will need a camber kit if u dont already have one...
But if ur on a really tight budget u could get by with just springs on stock struts only if u getn tein springs...
| All times are GMT -8. The time now is 09:58 PM. |
