500HP what brakes?
Old May 29, 2007 | 07:44 PM
k_dogg70's Avatar
Default 500HP what brakes?
I am currently overhauling a 93 integra and modding it up to have around 500hp. Can i have recommendations for a brakes upgrade.
It is currently 4wheel disk. Should i get better rotors, pads, calibers? What brands are better than others? Does brembo make brakes for honda? i know brembo for the best brakes for bikes, anyway thanks
Old May 29, 2007 | 07:50 PM
SovXietday's Avatar
Default RE: 500HP what brakes?
Most people just use stock.
Old May 29, 2007 | 07:56 PM
MTK's Avatar
MTK
If your willing to dish out the $2K price tag, Brembo GT Brake Kit is the best in the market...not 100% sure if they make it for 93 tegs tho, so sorry i can't be much help...
Old May 29, 2007 | 08:08 PM
civicexracer's Avatar
i assume this is only a drag car so some Brembo slotted and Hawk HPS pads should be plenty to slow ya down.
Old May 29, 2007 | 08:18 PM
AgentofDarkness's Avatar
It depends what kind of racing you will be doing. If you are doing drag racing then you shouldn't need a really aggressive brake set up so brembo slotted rotors + Hawk pads should do the trick. If you race at the track (non drag) then you might want to look into the Brembo big brake kit. The brembo set is $2k but I think other companies (willwood maybe) make cheaper kits.
Old May 30, 2007 | 03:06 PM
jhsplaya08's Avatar
brembo rules!! id have to save and get their big brake kit.
Old May 30, 2007 | 07:39 PM
SovXietday's Avatar
For a 500whp Honda, stock is more than enough. You won't have traction worth **** on the street, and at the track you've got quite a good amount of time to slow down. Brembo blanks and HAWK pads would be the most I'd put on it, but that's after you warp your stock brakes brake-boosting on a 600whp Nitrous Camaro... get what I'm saying?
Old May 30, 2007 | 08:41 PM
k_dogg70's Avatar
so with the stock i'll be fine? is there any aftermarket parts that i should avoid and any that are reccommended? thanks guys
Old May 31, 2007 | 08:38 PM
k_dogg70's Avatar
if i use brembo rotors and hawk pads will my stock calibers be ok? thanks
Old May 31, 2007 | 09:05 PM
ORIGINAL: k_dogg70
yes. im using Hawk HPS pads with oem rotors and oem calipers, no problems and i love how much better braking is. if i can do multiple autox runs with just these pads and oem rotors in 80+ degree weather with no problems, doing a few passes on a drag strip will be just fine.
