92 Civic rack and pinion replacing
Old Nov 1, 2005 | 10:17 AM
nelpasa's Avatar
Default 92 Civic rack and pinion replacing
Can I replace the rack and pinion without removing the engine?
I tried to disconnect the coupler between the steering column and the unit but could not get to the coupler's bolts. There is a coupler cover that I could not remove to gain access to the bolts.
Please help....
Old Nov 1, 2005 | 06:40 PM
AgentofDarkness's Avatar
Default RE: 92 Civic rack and pinion replacing
Do u need to replace teh whole steering system or just part of it? Also do u have power steering or not?
Old Nov 4, 2005 | 12:40 PM
nelpasa's Avatar
If i do not have to do it , I won't. My problem is the RH wheel has horizontal play, but the LH do not. Can I replace the RH side of the rack and pinion alone? Let me know ,please.
Old Nov 10, 2005 | 10:24 PM
I think you might be able to, because i was looking at the steering section of my service manual and it showed the rack taken apart, and it looks like it can be taken apart and one side replaced, but the rack is like $200 so it might not even be worth the trouble to fix the rack. Also, the part you need might not be sold seperatly.
Old Nov 10, 2005 | 10:38 PM
StifflersMom's Avatar
Cat Fuсker
You just can't find parts separately...good luck with it
Old Nov 10, 2005 | 10:48 PM
My thoughts exactly, i would just replace the whole rack. That way you don't have to worry bout talking a rack apart and putting it back together, and you have a new part you can be sure won't break at a later time.
Old Nov 13, 2005 | 03:24 PM
nelpasa's Avatar
WELL, I WAS TRYING TO REPLACE THE WHOLE RACK, BUT COULDN'T GET TO THE BOLTS HOLDING THE UNIT TO THE STEERING COLUMN. DO I HAVE TO REMOVE THE ENGINE TO DO IT?
Poe123
Jul 9, 2011 07:02 PM
curtdog21
Sep 25, 2009 08:36 AM
nelpasa
Oct 31, 2005 01:07 PM
AgentofDarkness
May 27, 2005 10:35 PM
AgentofDarkness
May 25, 2005 12:20 PM
