94 Civic EX drum shoe change
Old Jan 2, 2011 | 05:19 PM
dbrine's Avatar
Default 94 Civic EX drum shoe change
I'm changing the drum shoe on my 94 Civic EX. Went to Autozone and got them (Part # 576), installed them, but the drum won't fit. LOL. I loosen the star adjuster. But for some reason the dumb is resisting. Go Figure. Are they different sizes of drum shoes for the Civic? I also compared the new and old ones and they match.
What am I missing? Sorry for the retarded question. This is my first Honda. Any help is appreciated
94 Civic EX
5-speed
2 dr Coupe
Old Jan 2, 2011 | 05:59 PM
civicexracer's Avatar
As simple as it sounds, make sure the e-brake is all the way disengaged. Also make sure you're spinning the star wheels in the correct direction. They should be pulling the shoes inward to fit the drum properly. If your old drums are real old and worn, you'll have to spin the star wheels in a lot to fit the new drums since the new drums will have more metal in them. If you didn't replace the shoes, make sure they are evenly worn all around. Sometimes they can wear unevenly and have less pad in the center than the edges, though I doubt that would be the cause of the drums no fitting.
Old Jan 2, 2011 | 07:20 PM
dbrine's Avatar
I turned the star adjuster in almost all the way. Not sure WTH is going on. The ebrake is off also. Are there different size breaks for the Civic?
Old Jan 2, 2011 | 07:42 PM
If your adjuster and the shoes are all the way in, you probably have the wrong drum size.
Old Jan 3, 2011 | 06:22 PM
dbrine's Avatar
You'll never believe what the problem was....lol. I turned the star adjuster ALMOST all the way in... well I needed to go alittle but further. need to adjust them now. Thanks for all the help/ feedback
Li'l Red
Feb 19, 2011 08:08 PM
runrider
May 4, 2010 02:42 PM
Toppers
Aug 4, 2006 02:29 PM
tashi
13
Aug 26, 2005 09:22 AM
notb
Aug 1, 2005 11:05 PM
