94 cx suspension upgrade info needed?????
I'm lookin to add front and rear sway bars. Who makes reasonable kits for cars without factory bars? Also lookin to lower frontend just to get a slight rake from front to rear, to keep air from gettin under car. What options do I have and I'm not lookin to slam the car to the ground but make it handle better and be alittle more areodynamic, for drivin on long trips at 90mph. So let me have it.
Thanks |
RE: 94 cx suspension upgrade info needed?????
Well for the sway bars you will need to replace your front and rear LCA's cause only the Si had a fron sway bar. as for suspension it all depends on what you budget is, and are you looking for a more firm ride, or an almost oem one?
I'm lookin for as stock type setup as possible, not lookin to stiffen it up, just lower it an 1" or 2", so the simplest way would be fine, also I guess a camber kit would also be in the picture. So would it be new springs, coilovers, do I need different struts, bein 1" or 2" lower????? I'm not up on all the ways to do this on Hondas/Imports. I'm old school American rearwheel drive. So any ideas are welcome I'm lookin to learn and do it right. Not lookin to spend a fortune but money is not the issue. Right, reliable, simple, longevity.
So no one makes a kit to convert, without swappin control arms????? Thanks again.... |
i dont think a sway bar will lower your car...
Please read and understand the questions before replin, this was a 2 part question. One about swaybars and one about lowerin the frontend.
Thanks |
