94 integra to 94 civic rear disc swap issues
Its probably simple i tried using the FAQ link up top but seems to never find results with anything i type in to try and find an answer.... Anywho i swapped over the oversized rotors and calipers fromt he front of the integra as well as rear disc of the integra to my 94 civic ex and everythign bolted up just fine.... The integra had steel brake lines with it that i swapped as well no problems... The problem now is mushy brake pedal, ive bleed and bleed the brakes and still goes to the floor... Is there something i need or what am i missing something?
get a friend or family member to loosen a brake line at a time while you press the brake pedal push and release 3 times and on third thime push allll the way to the floor.. do this for each brake and then after that start it and press depress a couple times and it should get stiff, ive done this on many vehicles and it has worked great for me .. let me know how it goes
Originally Posted by catchmycivic252
(Post 775618)
