After market brake kits
Get a brembo big brake kit. I don't have one, and i've never installed one. But i have heard that big break kits make your car stop faster. If you want to do something a little cheaper (the big break kit is gonna run you around 1500) you can get metallic pads and slotted or drilled rotors. Also, if your car has rear dums, switchin it over to disks mite help.
plan on biger than 15" wheels if you havent already, but Powerslot makes a sweet brake kit that uses stock calipers, but the discs are (i think) 12.something inches. they are two piece, with an aluminum hat, which helps with heat control and cooling.
ORIGINAL: sacicons
go with brembo or wilwood....both are the highist quailty and look sooo hot behind a set of rims
http://www.wilwood.com/BrakeKits/index.asp
[IMG]local://upfiles/2140/12F826652E024B27897361E78544EB50.jpg[/IMG]
if you want really good brake system that wont break your credit card....go to
www.fastbrakes.com
and they have all kinds of kits for hondas, anything from complete upgrades to just pads.......there kits work so damn good, and are really cheap compared to some
www.fastbrakes.com
