alignment shop question.... with coilovers
well local midus doesnt have a inground alignment rack...
SO ive been thinking...... if i could lift the coilovers to get onto the rack and then set the coilovers to be as low as i want and even, then have them do the alignment and then me lift the coilovers to get off the lift and then with my measurements lower the coilovers again to my alignment height..... in theory that should work right? im just trying to get out of having to build a somewhat LARGE ramp to get onto there rack.. i like midus because they give ya the alignment print out sheet so you know its done right..... |
RE: alignment shop question.... with coil overs
The chances of you getting that perfect are slim to none but if you make good measurements then it will be close.
