Annoying squeaking noise
everytime i go to drive off from a stop there is this squeaking noise coming from the front end of the car and i know it isnt the struts or spring because it did the noise with them being stock and recently replaced them with skunk 2 coil overs and tokico struts and the noise is still there....it sounds like something is loose or metal against metal..its a loud squeak...anyone help? thanks konrad
RE: Annoying squeaking noise
Make sure all the suspension bolts, wheel nuts, etc. are tight. If that doesn't work, lube up your balljoints and tie-rod ends.
Take the wheel off, check your brakes, check your rotors, make sure they are all clean, if they got rust, turn the rotors and change pads, suspension bolts under the hood, check the control arm bolts, grease up all the joints.
