BALL JOINT AGAIN!!!!!
Old Feb 25, 2008 | 01:56 PM
branx's Avatar
Member
Default BALL JOINT AGAIN!!!!!
ok well i think i am only gonna do the upper ball joints for now since it is freezing outside and im kinda limited with time,... are the uppers also hard to do or should they be easier?? i know that my uppers are bad since the rubber partaround the joint is all ripped and i can shake the metal piece that comesfrom the joint,is there a way to check may lowers aswell?once again any tips would help, thnx
Old Feb 25, 2008 | 02:39 PM
Default RE: BALL JOINT AGAIN!!!!!
Old Feb 25, 2008 | 10:09 PM
gsumano's Avatar
The uppers ball joints are a lot easier to install since you have more room and also because you can easily remove the upper control to press the new ball joint in.
SiX
May 2, 2007 12:20 AM
DenzComp
Oct 11, 2006 12:54 AM
DenzComp
Oct 1, 2006 10:25 PM
anthony_delprete84
Aug 9, 2006 09:11 AM
Unc0ntr0l
Apr 17, 2006 03:26 PM
