Best tires for mpg.
Old Apr 29, 2010 | 10:35 AM
kjsayers's Avatar
Default Best tires for mpg.
I am need of new tires for my 06 ex sedan. Stock size is 205-55-16. I would like to stay with stock size. I am looking for a set that will help increase the mpg or keep it the same. I understand going from a OE to something else may hurt my mpg...how much truth is in this? I need an all season since i live in Indiana. Not looking to spend $150 a tire nor am I willing to cheap out and get some crap that will last 25k miles. Any suggestions?
Old Apr 29, 2010 | 11:23 AM
well as long as you stick with stock tire size, mpg shouldn't be affected. its if you switch to a different tire size that mpg get affected a little. check out tirerack.com they got reviews and road test on tires. also check out discounttire and tirerack
Old Apr 29, 2010 | 05:34 PM
hamorhead's Avatar
get low rolling resistance or LRR tires
they will improve mpg
also keeping them inflated to the max psi will increase gas milage
Old Apr 30, 2010 | 08:52 AM
theblackpearl's Avatar
if you're trying to save money, you may also consider getting tires with a very high treadlife rating. even though the ratings are different b/w manufacturers, it's still a good rule of thumb.
basically, if you replace your tires more frequently, then you'll spend more money....
silverbullet01
18
Aug 17, 2008 06:49 PM
remy
Aug 15, 2008 08:13 AM
kikaSI
Nov 13, 2006 11:52 PM
bloohatch
Jul 23, 2005 10:05 PM
oldschool
Apr 14, 2005 12:20 AM
