Brake Booster or Master Cylinder?
Old Oct 26, 2010 | 07:53 PM
Mad7s's Avatar
Default Brake Booster or Master Cylinder?
YO! crew, have myself a fanstastic brake issue. My brakes have zero for pressure with the pedal going all the way to the floor, no fluid in the reservoir, and fluid running down the back of the engine bay.............paint, LOVING IT! My thoughts are it's the master cylinder gone bad, but my manual "Helpful Haynes!" doesn't make clear whether or not it could be the brake booster. I just did the pads and rotors about a month and a half ago. They hadn't been done in a long time. Is it possible these cool fresh parts could have overloaded the initial pressure systems since they are the original cylinder and booster? Any and all comments and/or thoughts are appreciated.
-Kienan
Old Oct 27, 2010 | 08:05 PM
conceptualpolymer's Avatar
Can you see where the leak is coming from? Could it be a leaking fitting?
Here's a word of advice for when you are bleeding brakes: NEVER push your brake pedal all the way to the floor! When you do this, you expose the master cylinder piston seal to areas of the bore that are no longer smooth and the seal will get damaged. A power bleeder mounted to the master cylinder or pulling out the fluid at each bleeder by vacuum are better ways to bleed.
If you DO use the brake pedal, install a block of wood underneath to limit pedal and MC piston travel.
Old Oct 27, 2010 | 09:52 PM
Mad7s's Avatar
"NEVER push your brake pedal all the way to the floor!"
Good advice. Thanks for the response. It turned out to be the master cylinder being totally shot. I took it to my mechanic because I don't have the time to switch it out, and bleed the whole system before I go out of town this Friday.....600 miles up to Sierra Nevadas west of Sacramento.
Old Oct 30, 2010 | 12:23 PM
That's one thing you wouldn't want to delay. It's good to hear that it's replaced. 600 miles - that's a long drive.
MBrent
Sep 21, 2010 01:20 PM
j2performance
Jan 25, 2008 09:47 AM
sway2003
Dec 27, 2006 07:33 PM
campbuds
Jul 25, 2006 06:35 PM
campbuds
Jul 19, 2006 09:35 PM
