Brake Conversion
Old Jun 21, 2006 | 04:15 PM
m00chness's Avatar
Default Brake Conversion
Can someone hook me up with a link or two, and a general idea on how to convert a 94 civic ex back brakes from drum to pad?
Appreciate it.
Old Jun 21, 2006 | 04:35 PM
ef4life's Avatar
Default RE: Brake Conversion
get complete rear disc brake rear trailing arms, rear disc brake flexible brake lines, proportioning valve, larger master cylinder(not nessersary but good to get). and i think you need the parking brake cables from the rear disc car also
then install it all
Old Jun 21, 2006 | 11:18 PM
m00chness's Avatar
Any idea on cost, or where to find it?
Old Jun 21, 2006 | 11:46 PM
riceburner700's Avatar
if you want brand new upgraded larger disk for better stopping power check out
www.fastbrakes.com
can get like just rear kits or just front kits or even whole car kits...best bang for the buck brand new parts anywere
Old Jun 22, 2006 | 09:21 AM
StifflersMom's Avatar
Cat Fuсker
Don't listen to him...if you just want simple rear brakes for cheap, it can be had for as little as $300 if you shop around....plus your labor is free:-D
Old Jun 22, 2006 | 05:39 PM
Stimpy's Avatar
Its pretty much a no-brainer to do but it is a lot of hard wrenching if your car is rusty. To give you an idea, with new clean, loose parts I could do it in a half hour, but when I did it on my 95 it took me about 8 hours.
Old Jun 22, 2006 | 05:58 PM
Cat Fuсker
LCA bolts Baby:-D
Old Jun 22, 2006 | 06:15 PM
m00chness's Avatar
Awesome. I appreciate all the advice on it. Dont want to sound annoying asking the same questions over and over again but would you know any links that seel the parts I would need?
Also what donor car should I take the set up off of? (ive heard tegs and del sols but out of the two, which would you prefer. Or if there is a better third choice, Ide listen)
Old Jun 22, 2006 | 07:05 PM
Cat Fuсker
94-01 acura integra w/o ABS
Old Jun 22, 2006 | 08:30 PM
m00chness's Avatar
Youve been more then a help for me. If you want my yahoo name is m00chness> Always down to shoot the **** about rides.
lexicon
Sep 12, 2005 09:52 AM
spoonfed4uke
Aug 20, 2005 06:37 PM
civicpsycho
Jun 25, 2005 10:14 PM
ahhsimon
Jun 16, 2005 12:32 AM
civic1.5uk
Jul 30, 2004 11:57 AM
