brake problem
Old Jan 31, 2008 | 10:49 PM
hovo61788's Avatar
Default brake problem
alright so i was driving home from work tonite and i roll my window down to have a smoke and i hear this loud metal on metal sound coming from my front right. it happens when i brake and its even louder when i go 20-25 mph. i thought maybye if i try to warm the brakes up the sound will go away, it worked for a little while then the sound came back. after trying it again it went away. my dads volvo had the same problem with the rear brakes but i think its because his hand brake it broken. i dont know whats going on, im gonna change my rotor and pads tomorrow because it needs them. would it have anything to do with the axles?
thanks a lot guy for your responses this site is a life saver!!
Old Jan 31, 2008 | 11:55 PM
hovo61788's Avatar
Default RE: brake problem
so far the noise is gone but when i brake hard at 20 mph the car turns right pretty hard. it didnt move the steering wheel because theres a lot of snow outside. i dont know what that means exactly but i thought id tell you guys.
Old Feb 1, 2008 | 01:25 AM
Kommando's Avatar
I'm guessing that your brakes are overdue. You'll find that out for sure when you change them.
Old Feb 1, 2008 | 05:44 PM
I think you are hearing the brake pad wear indicator. The right pull may indicate that the right front brake pad is completely worn away, causing it to grab on the rotor when you brake. This problem needs immediate attention as you will or already have destroyed the rotor.
Ed Fisher
Aug 20, 2009 11:47 AM
Cosworth
Dec 15, 2008 05:35 AM
burgernuds
18
Aug 16, 2008 07:20 PM
j2performance
Jan 15, 2008 01:48 PM
Stumasters
Jan 17, 2007 01:36 AM
