Brakes are Squealing
Old Oct 9, 2007 | 04:55 AM
hoyafan100's Avatar
Default Brakes are Squealing
I have a quick question. I just took my 2004honda civic lx with 42,000 miles on it to the dealer. Everything was fine, just needed new brake fluid, oil and filter change. They told me my front brakes were 75% worn and the back ones were 25% worn. They cleaned and removed rust buildup from my rear brakes...it has been a week...Now I am getting a slight squeal from my rear brakes only when I take my foot off of the brake not when I press down on the brake? Think this is only temporary or should I get it looked at....its weird though, only after I take my foot off of it...let me know what you think..thanks!
Old Oct 9, 2007 | 08:13 AM
ic892003's Avatar
Default RE: Brakes are Squealing
are u sure its the rear brakes, isnt it ur front since ur brakeing is done with the front brakes and ebrake is the back, i would jus leave it if it is working fine
Old Oct 9, 2007 | 08:40 AM
Everyday Getaway's Avatar
When braking you use all 4 of your brakes, just most of the pressure is applied to the front. The rear brakes are not soley for parking... hence the lure of a rear disc conversion...
Old Oct 9, 2007 | 12:54 PM
jakeolas's Avatar
I have a similar problem. I just got my brake pads replaced and now whenever I'm cruising around, my wheel SQUEELS unless I either push on the brakes really hard really fast to stop it immediaetly, or when I just push on the brake normally.
Old Oct 9, 2007 | 01:07 PM
civicexracer's Avatar
probably didnt apply grease on the backing plates so whenever the shoes move, they rub and cause the squeal. so long as the pads and drums are fine and pedal pressure is normal, its not that big of a deal other than being noisy.
Mecca8383
Aug 24, 2010 05:05 PM
maris
Sep 9, 2009 06:26 PM
stancotreau
Nov 3, 2008 07:41 AM
ahhsimon
Jun 14, 2006 09:52 AM
faceless_civic
Nov 17, 2004 10:19 PM
