Broken Rear LCA bolt
Sure enough, when I was putting on my new springs, the head of the bolt where the LCA connects to the strut came right off. The other bolts came out fine though.
I picked up a new LCA and new struts. For now, I'm using a bolt that matched the size of the original one that I found from pepboys. Will this work fine? Or should I get a factory bolt to put in there? |
You want the OEM bolt. It's way stronger than any garbage pepboys has. Though you will pay about $10-12 for one.
Originally Posted by StifflersMom
(Post 723802)
Thanks |
Dealer would probably be the fastest, ordering online will only save you a couple bucks probably..
You don't want to order that online. They'll rape you with shipping. They use a pretty flat-rate system and you'll end up paying $10 shipping just for a couple bolts.
This happened to me once, after the bolt broke i replaced with another one off the shelf,
50 miles latter it broke. Get a OEM one. |
I just got a grade 8 bolt off the shelf and have been fine but you would want to go with a grade 8 for sure.
order from www.hondapartsunlimited.com i get all my bolts, OEM equipment from there all the time. i broke mine off last sat & ordered new ones. they have eveything and they ship within a week
same happen to me when i bought my civic [ except the idiots welded the strut where the bolt's broke] i went to a junk yard and got the bolts for 50 cents a piece
