Choosing rim size
Old Jan 1, 2007 | 01:51 AM
98civex's Avatar
Default Choosing rim size
so i was wondering something. say i wanted to upgrade to rims, would it be best if running stock car to get rims/tires that equal total diamater of stock steelies/tires? it would seem as if you just went ahead and bought any size rim bigger than stock that the engine will lag on take off due to final gear ratio now being different, is this true or does it not matter? thanks
Old Jan 1, 2007 | 10:21 AM
Marty's Avatar
Default RE: Choosing rim size
16 inch rims are a good size
Old Jan 1, 2007 | 11:14 AM
98civex's Avatar
what about size of tire, how low of a profile would you go to meet stock diamater of originals?
Old Jan 1, 2007 | 11:51 AM
Misha's Avatar
I believe that is what Marty meant - 16 beinga rim size for which youcan stil find a low profile tire to match stock overall diameter. Don't know exact profile percentage, though.
And you are right, if you go bigger overall, you will hurt acceleration due to what you called "final gear ratio". Another thing that will hurt your acceleration is the bigger moment of inertia of all rim sizes bigger than stock, btw.
Old Jan 1, 2007 | 12:14 PM
mxs's Avatar
mxs
ORIGINAL: 98civex
tell me what car you have, I'll tell you what size tires
yes, you have to match the original overall diameter.
Old Jan 1, 2007 | 12:17 PM
98civex's Avatar
98 civic ex. i was lookin into using si rims if i could find some, then i thought about the size issue.
Old Jan 1, 2007 | 12:18 PM
mxs's Avatar
mxs
<-- duh!
you will be fine
195/55-15 (stock size for a Si)
Old Jan 1, 2007 | 01:03 PM
98civex's Avatar
sounds like a perfect swap for stock P185/65R14 then. thanks a lot.
Old Jan 1, 2007 | 01:21 PM
conceptualpolymer's Avatar
I'm looking into this issue, myself. (I have a 97 CX). It looks like to me that there are more choices in 16-inch wheels and tires, today. If you go to www.tirerack.com and click on the wheels button, you can select among hundreds of different styles. You can even restrict what you are shown by wheel size. By entering the year, make, and model of your car, you can see whet your selection of wheels will look like on your car. I found some forged aluminum Traklite wheels that are extremely light-weight. This is important if ride and acceleration are high on your list. The lighter the wheels, the better the ride, if comparing the same sizes. I found 16-inch wheels that are only 12 lbs each. A 15-inch Traklite 2.0 wheel is only 10 lbs each - that's light!
Old Jan 1, 2007 | 03:31 PM
riceburner700's Avatar
15's or 16's would be just right
