Coil-Over problem
Old Jul 8, 2008 | 08:07 AM
imjrk's Avatar
Default Coil-Over problem
Have a '97 Civic with a coil-over setup. Need to replace the rear KYB AGX adjustable shocks. I cannot get the coil-over setup off of the old shocks. I believe they should just slide off, but I have tried a puller with an air wrench, to no avail. Any idea on how to get these things removed so I can use them on the new shocks?
[IMG]local://upfiles/26653/09690153BAF64A78B0EB88FCF67B8C93.jpg[/IMG]
Old Jul 8, 2008 | 10:21 AM
danomatic93's Avatar
June 2010 ROTM
Default RE: Coil-Over problem
-Spin the adjustable perches as high as they go.
-Since the shock is already broken, with the shock assembly upside-down, get a hammer a punch (or screwdriver) and tap the perches in a star pattern.
Gradually use more strength until the sleeves come off.
Use this for reference:
https://www.hondacivicforum.com/m_570002/tm.htm
Old Jul 8, 2008 | 12:42 PM
When I changed the shocks with my ground controls, I wound the perch down so there was maybe half an inch between the spring perch thing on the shock and the spring perch on the coilover sleeve. Then, I took a hammer and put the claw end in the gap (with the handle of the hammer pointing towards the top of the shock) and used it to pry the shock and sleeve loose. It's actually really effective.
Old Jul 8, 2008 | 06:39 PM
imjrk's Avatar
I put a three claw puller on it, put my airwrench on it and it didn't budge, at all!
Old Jul 8, 2008 | 09:08 PM
maybe use some PB blaster if you can get any in between the sleeve and shock
vdog
Aug 25, 2005 01:56 PM
k2rad
Jun 24, 2005 02:25 PM
Struletz
27
Apr 3, 2005 12:36 PM
pimp95civ
Oct 6, 2004 01:14 PM
civicjuju
16
Sep 24, 2004 08:25 PM
