coilover adjustment
Old Aug 30, 2008 | 09:32 PM
burgernuds's Avatar
Default coilover adjustment
hey i just noticed that one of my rear coilovers is slightly higher than the other. I counted the ridges and I have 9 on one side and 8 on the other. Is this a big deal or should I go through the trouble of adjusting it?
Old Aug 30, 2008 | 09:54 PM
i would say it's not a big deal
but if you're obsessive compulsive though about that kind of stuff, like i am, it will bug you and you'll adjust it even if it doesn't make a difference
lol
Old Aug 30, 2008 | 10:25 PM
burgernuds's Avatar
i don't want to go through the trouble and risk that chance of messing it up further.
I think theres like 1/8 of an inch difference.
Old Aug 31, 2008 | 05:17 AM
QUESTION.... have you gotten a alignment since you first adjusted the coilovers? if YES then leave it alone. IF NO then just adjust it alittle more if you want and then go get a 4wheel alignnment ASAP!
Old Aug 31, 2008 | 07:28 AM
burgernuds's Avatar
yes i did get an alignment already, but not wheel balancing...
Old Aug 31, 2008 | 11:10 AM
balancing does nothing but get rid of some vibrations alignment is whats important. i wouldnt touch the coilovers then! even a small fraction will effect your tire wear and sooner than you know it your tires are worn badly in the rear!
Old Aug 31, 2008 | 01:23 PM
burgernuds's Avatar
so the 1 ridge difference of about 1/8 of an inch shouldn't matter much?
Old Aug 31, 2008 | 01:55 PM
^exactly
when you sit in your car you lower the driver side of the car just a little bit.
the 1/8" off coilover is about equivalent to the effect of having the weight in your car slightly unevenly distributed, which is probably always.
Old Aug 31, 2008 | 02:24 PM
ya what ever the car was aligned to is what matters... the car maybe slightly up on that one tire BUT REALLY one turn is just a fraction... not with it IMO unless you want to pay for another alignment...
Old Aug 31, 2008 | 05:30 PM
burgernuds's Avatar
thanks a lot - and luckily the higher side is the gas side so it probably balances it self out. thanks again
