Coilovers
I think I've decided to go with Tien Type Flex Full Coilovers. What do you think. Is there anything else I should do while putting it in? IE camber kit, controller arms and so on.
Thanks |
RE: Coilovers
camber kit mostly likely be needed unless you dont mind buring through tires fast...not to sure abotu control arms, i didnt replace them when i dropped my car and its fine
RE: Coilovers
Camber kit depending on how low your going to go, but you got coilovers...so your going to go low:D. But you will be really happy with thos I think, they are a really nice set, and tein is a great company. You just need to get EDFC and you will be set.
RE: Coilovers
You just blew right by me:) What's an EDFC and what is it for?
RE: Coilovers
edfc is tein's electronic damping force controller. its is really cool and from inside the car you can control how stiff they are. the name says it all. i think its about $400
RE: Coilovers
Ya what he said^. You controle the soft/stiffness of your shocks from inside your car. Change it when you want. It is expensive, but if your going to do tracking events and such its a good idea.
RE: Coilovers
The car will also be a daily driver, is that unit still recommended?
RE: Coilovers
ORIGINAL: Oldman_civic The car will also be a daily driver, is that unit still recommended? Some really high end cars have the same stype of systems from the dealer. |
