Coilovers
its not really camber. its the toe eating up your tire.... your draging them basicaly sideways....
just go get a alignment and tell them to do there best, but the camber is not adjustable on stock .... and if you ever adjust your coilovers again then get a alignment again right afterwards!
your draging the center corner of the tires to the steel belts. NOT GOOD! so now you probably gotta get new tires! a alignment is ALWAYS cheaper than new tires!
Yeah, it's your toe that's destroying the tires. Get it set back to factory specs at an alignment shop and you're good to go. Trust me, I'm rocking 3* of negative camber all around with no premature tire wear.
arcmt33
Nov 20, 2009 02:34 PM
westpc7
Oct 28, 2004 10:38 PM
Civic Mania 160
Sep 15, 2004 09:23 PM
FoolishProdigy
May 1, 2004 08:52 PM
