curious question??
Old Mar 12, 2005 | 12:43 AM
seigi's Avatar
Default curious question??
Is it ok for a civic to only have the front end dropped? Here's my dilema... the gap between the front tire and fender is bigger than the gap between the rear tire and rear fender. I just want to close that gap in the front and make it smaller than the gap in the back so it doesn't look like I'm 4x4'ing. I guess I want to know if it's ok to have custom springs/shocks or whatever in the front and stock suspension in the back?
Old Sep 30, 2006 | 03:46 AM
Lordnismo's Avatar
Default RE: curious question??
Yea it wont hurt anything but I would buy coil overs ajustable and go that route. Dont customize you stock springs thats bad.
Old Oct 4, 2006 | 09:50 PM
mousetopher's Avatar
To start, I dont believe in cutting springs. But I did it as a temporary fix today. I cut my front springs to close my front wheel gap. I am actually impressed how it came out. It looks good, rides the same as it did before, and it only rubbed on hard corners (which I fixed). The only problem is that my alignment is screwed. But that will be fixed tomorrow. But for a long term fix, do it right. Adjustables or drop springs.
Old Oct 5, 2006 | 12:32 PM
seriously, cutting your springs is a HUGE NO NO!!!
Also, if you only do drop springs in the front, your car will look like a horny cat
Old Oct 5, 2006 | 02:35 PM
civicexracer's Avatar
dont cut ur springs. be paitient and save up about $150 for some stechs or somethin. also, if just put lowering springs on ur front end, then ur car will handle like ****.
Old Oct 5, 2006 | 02:36 PM
Remmy's Avatar
Cutting your springs is dangerous. Just simply get aftermarket springs.
Old Oct 5, 2006 | 05:26 PM
TheMoogly's Avatar
ORIGINAL: Forty04
THAT IS WAAAY FUNNY!
Old Oct 5, 2006 | 09:41 PM
R35P3KT's Avatar
haha horny cat a.k.a "lowriding pu$$y" w/e u prefer......
Old Oct 8, 2006 | 10:52 AM
FlipHKD720's Avatar
ORIGINAL: Forty04
wow, i laughed way too hard at that.
Old Oct 9, 2006 | 08:59 AM
rit14623's Avatar
I would not suggest lowering only the front end. Lower both the front and back. After-market springs come in sets of 4 anyway.
