Dragging brake or bearings?
Old Feb 17, 2009 | 05:05 PM
hekla's Avatar
Default Dragging brake or bearings?
HI guys . I`m getting a noise from the back of my 05 SE (drums). Sounds to be a dragging shoe type sound mainly
when I`m hard on the wheel either left or right. I pulled off the drum and everything appeared to be in decent shape.
I`m now thinking E-brake adjustment?? Or could this be a bearing issue and not the brakes? ( I pull a light trailer with my MX in the summer and my sled in the winter) WHat do you think? DO I have to pull the wheel again- or can I adjust at the lever.THanks
Old Feb 18, 2009 | 07:23 AM
project5k's Avatar
if your only hearing it when your hard on the wheel(turning left or right) then i would think that something is rubbing when under a side load, and thus i would check wheel bearings, and suspension stuff.. are you sure its the brakes that your hearing, and not the tire rubbing inside the wheel well?
thakid
Dec 14, 2011 01:48 PM
ErikElvis
Dec 8, 2007 09:44 PM
snosurfa7
Jun 12, 2007 09:31 PM
snosurfa7
Jun 9, 2007 01:18 PM
mcoulter
Oct 18, 2006 11:24 AM
