DRUM TO DISC CONVERSION
can some one give me a list of wat all i will need parts wise for the drum to disc conversion and i know i ill need some acura rear brake assemblies please tell wat else if anything im a newbie here so lamens terms please lmao hahahaha
RE: DRUM TO DISC CONVERSION
yea i need some info please
I'm in the process of doing this as we speak. all you are going to need is the rear trailing arm(complete) from a 94-00 integra.And the e-brake cable and then the rest you will reuse It took me awhile to find one for a good price but from what I have read they are getting harder to come by. But if you search this site you will find a lot of info and links about it, but so far the best source I have come by is the diy network. Check it out it outlines everything from cleaning the parts to the install. And its not a bad idea to replace the rear bushing in the arm while its easily excisable. here are a few pics of the process...I did one at a time(since I had the time)so I could use the other one as a refrence to the other one(thou once apart there are only a hand full of parts). Good Luck
http://www.diynetwork.com/diy/ab_bra...275324,00.html [IMG]local://upfiles/23059/908D7AFC03E24C9C80F2F39EDC4F9F1B.jpg[/IMG] [IMG]local://upfiles/23059/B0CE2B20E59D48208648D94510538B84.jpg[/IMG] [IMG]local://upfiles/23059/36268F1CE3C442449D114D184D73D75D.jpg[/IMG] [IMG]local://upfiles/23059/24215DCE611F453EAE276580B11DE86F.jpg[/IMG] [IMG]local://upfiles/23059/BBE316211F30445E84116502ED489462.jpg[/IMG] |
ive always WANTED to do this mod... but i just see beter things to spend my money on.....LOL
ive seen quite a few put together kits on ebay from time to time... that go actualy preaty cheap..... tho if i was to put it together id buy mostly new or refurbished parts.... cause brakes are preaty important..... and with doing a swap youd HATE to get that one bad part and not know WTF is wrong.... |
