fitting coilovers
just got a set of coilovers on ebay from usa waitin for pybgas shocks to turn up.
i can fit the shock itself but does any1 know how 2 fit springs to shock ?? were do these washers go??? gettin a new set of15s off ebayim stuck on 13s! will this be 2 low?? will the handling be affected without camber kits?? should i just did deep an get honda 2 fit them?? thanks for any help |
RE: fitting coilovers
thanks very much!!!!!#
you should do the camber kits, otherwise you could compromise your handleing if your riding with to much negative caber depending on your drop.
ok going to get camber kit its just goin to take a while till i can afford to get them and pay honda.
any views on lower tie bars and upper strut braces front and rear??? and how cums every things cheeper in the states but they wont ship over seas? |
ORIGINAL: warner_ro you should do the camber kits, otherwise you could compromise your handleing if your riding with to much negative caber depending on your drop. |
booked in for wheel ali wen the tyres go on soon as i fit the shocks this weekend looks easy enough should be fun!
thanks for the help swede |
