is this gonna be ok?
Old Mar 18, 2008 | 07:41 AM
hovo61788's Avatar
Default is this gonna be ok?
my buddy is selling rims like these. there from a vw. would these work. is the offset gonna be ok? you guys think those would look good on a black 98 civic? thanks!!
Old Mar 18, 2008 | 11:40 AM
macbeth18288's Avatar
Default RE: is this gonna be ok?
Wow.....
IMO those are the ugliest wheels I have seen in a while.
They have the 4 bolt pattern so they will fit
Not sure about the offset though.
Old Mar 18, 2008 | 01:03 PM
They have a +35mm offset.. I'm not quite confident that they won't rub if you lower, especially with how wide they are.
and +1 on the ugly comment
Old Mar 19, 2008 | 02:58 AM
importcivicus's Avatar
there not ugly oh man how can i say this ahh "THERE FUGLY."
Old Mar 19, 2008 | 04:03 AM
alecrust's Avatar
Yeah, dude those wheels suck...
Old Mar 19, 2008 | 05:44 AM
mxs's Avatar
mxs
Those wheels are pretty badass, although they would look better on an older car. The offset will be ok, especially if you are on stock suspension.
Old Mar 19, 2008 | 10:11 AM
bakertime's Avatar
If you ever lower, you'll have to run some negative camber to prevent rubbing probably. Other then that you should be alright.
Old Mar 19, 2008 | 05:40 PM
White Mischief's Avatar
They should be OK. I had a set of snows from an 85 GTI that bolted right on to an 89 Civic I had. The bolt pattern is the same for both although I speak on the offset.
Old Mar 20, 2008 | 10:23 AM
B!@ckBoYwiTaC!v!c's Avatar
dude those rims are sick. I think they would look great on an old civic. Just make sure you don't lower too much or if you do get some camber kitz to make the rubbing go away.
D16z6
Feb 11, 2006 01:33 AM
2000 LoW reD Si
Jan 24, 2006 05:05 PM
amg6975
Oct 12, 2005 09:17 AM
carlover
Sep 6, 2005 02:47 PM
