Help with Brake problem
Help
I have a problem with the brakes on my Accord 95 Ex. After coming to a stop the brake pedal start slower moving to the floor. can someone tell me how to fix this problem. Thanks for the help |
RE: Help with Brake problem
Check to see if it is leaking, if yes.. then your problem is traceable, an easy fix..
Question..! When you first step on to brake.. it brakes but as u holding on da pedal it started to sink slowly, all the way to the floor or stop at certain level. There're different if it sink to da floor or stop at certain level. If it stop at a certain level (not to the floor as you wait @ a stop light) then your problem might be the master cylinder (consider if it has no dectable leaks) If it sinks to the floor while waiting at the traffic light, then it's yours brake booster. |
Sounds like your master cylinder may have fluid leak. Or you have no fluid.
master cylinder has a leak...
droppy 128
It slowly sinks to the floor while waiting at the traffic light. Were is the braker booster? Thanks |
Brake booster is the big round thing where your master cylinder attached to..
