HELP!! Can a camber kit fix my problem??
Hello. I have a 2001 Honda civic lx sedan. I lowered the car a couple months ago. I put on an Eibach Pro-Kit (about 1" drop) and Tokico HP series (blue) shocks/struts at all four corners. The rear wheels are now leaning in which is causing the inside of the tire to wear. How can I fix this? Would a camber kit help? If a camber kit would help this, are they difficult to install. I would like to get this problem fixed before I put on my snow tires. I appreaciate any help. Thanks!
yes it would help but you will need an alignment
very easy to install that is if you dont break any bolts |
