Help me guys!!
Old Mar 10, 2010 | 08:53 PM
Shinobi's Avatar
Question Help me guys!!
I have a civic 97 lx with stock suspension right now. I was hoping if you guys on here could let me know what's best out there right now for shock, chamber kits, and springs at a very low prices. Sorry on a major budget after got a $391 magnaflow exhaust system.
Old Mar 10, 2010 | 08:55 PM
Shinobi's Avatar
"Remebering what you did yesterday, but remenber what you did today"
Old Mar 10, 2010 | 10:14 PM
How low are you expecting to spend?
How low do you want the car to be?
Are you wanting very increased handling or is this all for looks?
You don't really need a camber kit, especially if you're on a tight budget... get an alignment after lowering and it'll be okay.
Old Mar 11, 2010 | 04:55 AM
^Truth!
And honestly, you spent a good amount of money on a peice of piping, but want to cheap out on your suspension?! Priorities my friend, get em in order
Seriously though, save up some money and hold off until you can afford something worthwhile, you will NOT be dissappointed
Old Mar 11, 2010 | 05:20 AM
Shinobi's Avatar
1.5-2? if that is good for my civic which have a front lip. As for spending to lower is about $400-$500 the most for everything. Oh really?...I hearded chamberkit is a great way to balancing ur wheels out and not give to much stress on the bearing or the shocks/springs itself if were using a stock chamber. I want to do it one time just right and just dont want to have it wear and tear on me at 7 or 9 months in driving. I want increase in handling more and also for the look...cmon now, everybody now a day does for the look ever with jeeps,hummer, other american cars lol. Also I don't want it so low that 2 of my back wheel indent into the side.
Old Mar 11, 2010 | 05:24 AM
Shinobi's Avatar
Originally Posted by Forty04
^Truth!
magnaflow is worth it. Its the best exhaust system I ever had so if I do spend on this then why wouldn't be worthwhile?. Also not any peice of piping but an exhaust system! which improved in my hp greatly. I know what you mean but I had to spend it because my old one is about to break and fall off.
Old Mar 11, 2010 | 07:05 AM
Exhaust did not increase your hp at all, sorry lolllllll.
You don't need a CAMBER kit Shinobi.
This topic is one of the most frequently asked on one of our major customer sites. So, rather than continue to post wordy replies over and over again, we are making it a tech article!
Do I need a camber kit? The short answer is: If you are worried about your tires, then no. If you are more **** about your car and want all the numbers correct, then yes. For the long answer, keep reading.
Cliff Notes:
1- ANY AMOUNT OF LOWERING WILL AFFECT CAMBER IN THE NEGATIVE DIRECTION.
2- THE CAMBER WILL NOT RESULT IN EXCESS TIRE WEAR BUT WILL RESULT IN ALIGNMENT ANGLES WHICH ARE NOT IDEAL OR ARE OUT OF SPEC. THE CAMBER WILL LIKELY BE VISUALLY APPARENT.
3- THE ONLY WAY TO FIX NEGATIVE CAMBER ON HONDA/ACURA VEHICLES IS WITH A CAMBER KIT.
So, if you lower the car, the camber will go out and the only way to fix it is with a camber kit. But I see no specific need to actually go through with fixing it.
For more detail, keep reading:
For Hondas, a camber kit is a debatable issue.
When you lower the car, the camber will go out and you need a camber kit to fix it. However, I find it is not necessary to correct the camber in most cases. Most people think they need a camber kit because of a tire-wear concern. The reality is, TOE ANGLE kills tires WAY faster than camber ever will.
Sound like a bold statement? Conventional wisdom is that when you lower the car you need a camber kit if you don't wanna wear out the tires fast. Well, there is another adjustment/spec here than nobody has mentioned. Caster is another key.
When you lower a double wishbone car like the 88-00 Civics, 90-01 Integras, Accords, TSX, etc, the camber angle always increases in a negative direction: The wheels tilt inwards. It is what makes the car handle better in turns than strut cars. It is a natural effect of cycling a double-wishbone suspension.
Lowering many cars also increases the toe angle, which is to say it points the tires outward. They kinda fight for direction where the car wants to go.
But also, realize that all cars have some positive caster. The means that when you turn the wheel, the axis of rotation is not 90 degrees. You may notice it more exaggerated on BMWs and Benzes. The best way to view the angle is to turn the wheel all the way to one side, and get out and look at your car. Notice the wheel is turned, but also kind flopped over? Have a friend with a S500 (if you have one) do donuts while you watch outside. The wheels really flop over on those cars!
Think of it like pushing a wheel barrow. The angle from the axle to the handle is like caster. Pick up a wheel barrow and stand it veritcal on the tire with the handles straight in the air. Now imagine pushing it and trying to turn it. Haha...it just fell on you! Now imagine pushing and turning it normally. Much easier. Much more stable. And when you trun it, the tire is not actually turning. It flops over on it's side and leans! That is how your car turns too! That is how motorcylcles turn and well.
Caster is great for high speed stability. That is why all cars have some dialed in. Without it, the car would be super twitchy and hard to control at speed. It's why autobahn burners have more caster than your typical Japanese car.
The problem is, when you lower the car and toe angle is thrown out, the wheels are actually riding on the inside edges of the tire as they grind away pulling the car in different directions! This is in addition to the increased camber effect! With an improper alignment the car will WASTE tires in a matter of months (or weeks if you drive like me).
The trick to lowering the car and having the tires last is to get a good 4-wheel alignment to fix the toe angle. I AM COMPLETELY SERIOUS when I say that, as an authorized Tein distributor, 9 times out of ten we do not sell a camber kit. I have had over a dozen hondas, all lowered, and most lowered past 2". I have never had a camber kit on ANY of my cars. The ONLY car that I had a problem with tires with was my 94 accord which I had never aligned. Go figure.
Camber will tend to wear tires out somewhat quicker than stock, but generally speaking, with a good toe alignment, the increased wear will not be cumbersome or even really significant. The added camber actually makes the car handle a little better. Also, a little camber in conjuntion with the caster will wear the tires out almost evenly! So why get rid of it?
Here are some images to illustrate what I mean.
In this image, you can see where the inside and outside of the tire are. The red dots are there to help you identify the wear-indicators inside the tire grooves. When the tires wear down to these wear-bars, you know it is time to replace the tires. These tires are almost there:
Now, you can see how the tire is worn more toward the inside...that's camber wear. This customer was driving on this tire, with the car lowered moderately with a good alignment. He has not maximized tire wear, but clearly he has not greatly suffered either. No camber kit was installed.
In the next image, we have a tire which was lowered aggressively, and the car was NOT aligned.
Look how aggressively the tire has worn on the inside edge. The cords are even showing. This wear is caused by TOE angle. The direction of wear here is dramatically different than a camber-worn tire. This type of wear will kill a brand new set of tires in a matter of months. Mistakenly, people will lower their cars, not align them, get this wear, and blame it on camber. The timeline continues when the customer buys a camber kit, installs it, and the wear goes away. Must have been the camber kit, right? It was the toe, people. Also note, this is a front tire.
With a drop under 1.75", you should not need to even worry about it, because a drop of that much will not even throw the car out of factory camber specs! But that toe will be in the red every time!
Other things of note!
Camber and Caster are not adjustable on our Honda cars! I think we already know that , but I was just noting it. Toe is fully adjustable front and rear.
Front tires always wear faster than rear ones. The wheels back there are just free wheeling. There is little weight on them and the is no load/torque on them. Traction is not an issue and wear is nearly non-existant. If you are going to get a camber kit for your Honda, you only really need it in the front.
Some people wonder why Hondas do not have camber-adjustable pillow mounts available. The reason is simple. It's that Double-Wishbone suspension thing again. Cars which have camber adjustable pillow mounts awailable are all MacPherson strut suspension cars. In a MacPherson car, where struts are used, the damper locates the steering knuckle; it itself is a suspension member. In a Double-Wishbone car, upper and lower arms locate the knuckle, and the shock and spring are attached to one of the arms to provide dampening. So you see, with arms locating the knuckle, moving the shock around really does not change any alignment angles. So having camber adjustable upper pillow mounts on these applications is utterly pointless.
Alignment shops are like body shops. Most of them suck, but they are a necessary evil in our world. The trick is to find a good one you like. I hear a lot of good thigs about west-end. There are a couple in South Orange County here I recommend. I know a lot about alignments because I did them at work for a while. I wish I had an alignment machine JUST so I could do my own now!
Negative camber is visually apparent from outside the car. This is a big deal to some people. Likewise, I am not trying to tell people that lowering the car will not result in negative camber which is out of spec. All I am saying is that is does not have a big impact. Really, to fix the looks and alginment numbers, you'd need a camber kit. Some people just have different prioritys.
That's it for this posting. Thanks for reading! Feel free to reply!
Marcus
Old Mar 11, 2010 | 08:02 AM
Weak. It's not a drop unless you're tucking
You're not going to put enough stress on the hubs, bearings, or axles to cause any real damage by lowering it. My old civic was lowered ~3-3.5" in front and ~3.5-4" in back and I had to replace two wheel bearings... because the car had 100,000 miles on it and still had the original bearings. As far as camber goes, like NIKE posted, it will not cause noticeable wear provided your toe is in spec (actually, I have one problem with the quote he posted. Less positive (it's actually very hard to have a car with true negative caster) caster will not wear your tires; the camber roll during turning will actually decrease with less caster, meaning less tire wear). I had -3.0 degrees of camber on all four corners of my civic with no noticeable tire wear in 10,000 miles; one of our moderators, Wellfedhobo, can verify this; he bought the wheels and tires from me after I sold the car.
Buying a new exhaust because your old one is a legitimate reason. However, the power gain you feel is 98% placebo; a realistic gain from a 2.5" cat-back on a bolt-on civic would be somewhere between 2 and 4 horsepower, which is not even close to enough to feel. What Forty was getting at is you spent $400 on an exhaust which does little more than transmit exhaust gases to the rear of the car, yet you want to cheap out on the weight-bearing devices that support your 2200lb car. The suspension is not a good thing to try to save money on.
Anyway, check into Tein S-tech springs and Tokico HP struts; you can usually find them both fairly cheap. Like I said before, you don't really need a camber kit. The S-techs will lower you a little under 2" and have roughly double the spring-rate of the stock springs, so you'll have a noticeable decrease in body roll, pitch, and dive while doing some spirited driving.
Old Mar 11, 2010 | 12:32 PM
Well if you follow our advice about camber kits and not needing them you could be lowered for $500. If you don't, well you won't have enough money left for shocks and springs (or coilovers). I'd look into the set up that Reaper2022 mentioned, Tein S-tech springs and Tokico HP shocks
I'm lowered 1.8" and my tires just barely wear unevenly. I got an alignment and had the toe aligned after lowering. For over a year now i've been driving on the set of tires I have now and you would have to look very closely to tell that they are wearing slightly unevenly.
You can get front and rear camber kits if you want but it's gonna run you about $200-350. If your budget allowed it, I'd say go for it.
I myself plan on getting camber kits eventually, even though I know for a fact that my tires will be fine without it. I'll be getting them, well, because I just like doing different modifications and sooner or later i'll be working on the suspension... plus you get new upper ball joints out of it.
Old Mar 11, 2010 | 01:53 PM
civicexracer's Avatar
I don't know how low my car is inch wise, but the fender lip sits right above the tire. I can barely fit 1 finger inbetween all around. I've been running this height for a couple years and haven't had any major wear issues, and I DON'T have a camber kit. The way I keep my tires wearing fairly evenly is by frequently measuring tread depth and rotating the tires accordingly. With proper alignment, you shouldn have any issues. Buy a tread depth measuring tool, costs like $2. What I've notice with my wear, the inside 1/4 of the tire generally is about 1/32 less the the center and outside tire. 1/32 is nothing...
As for Shocks/springs, either KYB GR2's or Tokico HP's and Tein S.Techs would probably put you around $500, so you won't have enough for a camber kit anyways...
