How many washers for washer trick to fix in H tech install?
Old Apr 20, 2007 | 09:48 PM
snosurfa7's Avatar
Default How many washers for washer trick to fix in H tech install?
Tein H Techs, -1.3 front, -1.1 back - how many washers for the washer trick to fix camber in rear? B/t installing 2 or 3...
thanks
Old Apr 20, 2007 | 10:23 PM
mxs's Avatar
mxs
Default RE: How many washers for washer trick to fix in H tech install?
maybe one?
those springs are hardly a drop
Old Apr 20, 2007 | 10:27 PM
snosurfa7's Avatar
I read this DIY:
http://www.honda-acura.net/forums/sh...d.php?t=165815
Dude was installing H and R OE sports, only a -.75 drop and w/ one washer it was still way out of spec...So thats why I'm b/t 2-3...But thanks mxs, thats what I thought too initially, maybe only 1...and maybe the DIY is wrong, but given that dude has his alignment specs posted, I think I'll believe him.
Old Apr 21, 2007 | 12:26 PM
Powermidget's Avatar
i have the same springs as you and i dont have any negative camber
Old Apr 21, 2007 | 04:11 PM
snosurfa7's Avatar
Thanks...Do you have a 6th gen though? I wonder if that makes a difference. And I guess you mean you have no washers w/ your set-up, right?
thanks
Old Apr 25, 2007 | 11:58 AM
no i have a 4th gen, and i do nothave any washers and the car deoesnt squat....both are cars are double wishbone and that is a really slight drop so i dont think the 1.1 drop in the rear will cause any major if any negative camber....but just a side note if you got integra or after maket lca's that would correct a certain amount of negative camber
Old Apr 25, 2007 | 03:41 PM
ScoobyAddict14's Avatar
formerly aryiman98civic
i need 3 washers and my car is dropped about 2"
bmelloh
Aug 4, 2010 11:06 PM
GDizzle2
Jul 12, 2010 07:29 AM
Live_4it
Jun 19, 2008 06:36 PM
javon
Apr 6, 2008 06:32 PM
plethoric33
Oct 1, 2007 09:33 AM
