I NEED HELP!! 1991 DX bushings
Old Oct 29, 2007 | 02:58 PM
CivicDx91's Avatar
Default I NEED HELP!! 1991 DX bushings
I've been trying to get ahold of a press to press out the bushings on my 91 dx hatch. i'm replacing basically all of them and have no other idea on how to get them out of there, does anyone have any other ideas if the press is out of the question? i heard maybe a propane torch. please help, thanks!
Old Oct 29, 2007 | 04:06 PM
enigma34's Avatar
Default RE: I NEED HELP!! 1991 DX bushings
A torch. lots of cursing and swearing if you do it
yourself without the right tools.
Old Oct 29, 2007 | 04:35 PM
ya i would keep trying to find someone with a press!!!!!
i know the pushings in my LCA just the strut bushings i had to replace THEY WHERE REALY IN THIER!!!!!!!!!!!!
no way in hell a hammer would have removed them!!!!!
my dads press is 20tons and with 1 bushing it VERLY had the power to pop the one bushing out!!!! i was shocked!!!!! no way a sledge and vis woulda held it! hell i wouldnt be shocked if it actualy bent the control arm!
Old Oct 29, 2007 | 05:15 PM
mxs's Avatar
mxs
You need to burn the rubber out with a torch, and then cut the metal sleeve out. You do not need a press.
Old Oct 30, 2007 | 04:16 PM
CivicDx91's Avatar
what i did, for the lower control arm, was heat it up a lot with a torch, and then stick the end tight in a vise, and work the arm back and forth, until it broke free, then tapped it out with a hammer.
now, how would i go about pressing the new ones in there?
Old Oct 30, 2007 | 05:02 PM
freezer.... socket to fit the main bearing shaft and a big hammer
owensteph1
Jul 13, 2010 07:23 PM
MrLizard
Aug 21, 2008 01:53 PM
Brandon.Scott
Aug 18, 2008 06:26 AM
EJ8_Man
Feb 22, 2008 08:03 PM
brunborg
Jan 14, 2008 08:38 AM
