Ingalls Rear Camber Kit
I’m running into issue with my rear wheels, The inside of the tires are getting ware down, This is the 3ed set to tires. I been seeing that a lot of people are going with Ingalls Engineering Rear Camber Kit ??? Will this fix my issue? I took my car to the dealer and they said the service bulletin 08-001 is not for the SI... I so need to fix the issue... Any help would be great.
Thanks Vince |
Did you install lowering springs, or coilovers, or mess with the suspension (even if removing something and replacing it)? If yes, did you get an alignment done? If not, that is your problem.
Originally Posted by cvcrcr99
(Post 761739)
