Istalling Lowering Springs..
yeah if you haven't done it before you might want to take it to a shop to have them installed. You can take the strut assembly off complete with springs and take them to a shop to swap the springs. They are under a lot of pressure and if you have never used a spring compressor before you might want to see how it is used before you attempt it.
If you are set at doing it all yourself,... use extreme caution when compressing the springs and removing the center bolt.
definately get it done professionally if you have never used a spring compressor before. And if you dont have a spring compressor then definately dont do it yourself. Other than that its a simple install... just make sure you get an alignment done when its all over.
Struletz
27
Apr 3, 2005 12:36 PM
motegicivic99
Aug 9, 2004 05:50 AM
motegicivic99
Aug 7, 2004 01:56 PM
hondaholic9
Jun 19, 2004 11:41 PM
