LCA Bolt Broke ~ 99 Civic EX
Well was about to install my coilovers on my 99 Civic EX when I ran into a little problem which I heard is very common among Civic owners.
I had gotten the 2 front shock assemblies out along with the right rear shock assembly. While I was working on the last one (left rear), I was using a breaker bar to loosen the far left bolt on the lower control arm and surely enough, it broke alright... I ended up getting the assembly out but the lower control arm still has a broken bolt in it. http://i52.tinypic.com/nb3leq.png Above shows the bolt that I broke on my own car. My question is: what is the bolt exactly called (name or product number)? I don't want to walk in to my local Honda dealer and look like a ricer fan boy when I'm trying to explain what I need. |
Lower control arm bolt. All three are the same on EKs
Originally Posted by cvcrcr99
(Post 764672)
Can you get a picture of what's left of the bolt? It'll make it a lot easier for us to tell you how to get it out.
(Post 764680)
Send us a pic. You will probably have to heat up the bushing (to like a glowing orange) and then turn the bolt out from the other side (not the head assuming that broke off). You will be able to make it turn a few times before having to heat it up again. It is a painfully long process, but must be done. Please do not attempt to drive the vehicle without fixing that first. I had 4 bolts snap on me when I installed my coilovers on my 99.
Generously apply anti-seize on the new bolts when reinstalling. You will probably have to replace the bushing or the entire control arm, too. |
(Post 764686)
ew, don't get skunk2 lca's. the bushings will be torn in a year. Or at least the old design was crap, I think they have a new one.
I'd go with Function7's if I were you, those are supposedly the best. |
Originally Posted by Shandles
(Post 764734)
(Post 764734)
I'd go with Function7's if I were you, those are supposedly the best. OP, watch out for junk companies like Blox, blackworks, and anything no-named. |
