lowering springs & camber..
Old Jan 17, 2009 | 11:35 AM
boyitik45's Avatar
Default lowering springs & camber..
it necessary to have a camber kit (front & back) when you use lowering kits?
Old Jan 17, 2009 | 01:04 PM
Kommando's Avatar
If you're going more than .5" lower, it's recommended for the front. For the rear, you can search this site for "the washer trick" for an extremely inexpensive way to change your rear camber.
Old Jan 17, 2009 | 05:00 PM
I'm going to say no. As long as you get an alignment and have the toe set back to spec, you'll be fine. And I'm not just repeating things I've heard; I had my civic sitting on the ground (around a 3" drop) with 3* of negative camber all around. I had no premature tire wear whatsoever.
Old Jan 17, 2009 | 08:45 PM
boyitik45's Avatar
thanks guys..
Old Jan 27, 2009 | 01:58 AM
Robzilla's Avatar
With stock tires the inside edge wear is not as bad as with wider aftermarket wheels and tires. I have worn the inside edge of my rear tires on all 3 civics I've owned because of being lowered and negative camber, 97 coupe I did the washer/bolt trick to fix, on my 96 4door i left it alone and tore up tires. My 03 Si i have wore the inside edge on the rear with good tread on the outside. I have megan racing coilovers that have front camber plates. I just added a rear camber adjustment to straighten up the back.
jbum
Dec 29, 2014 11:08 AM
boyitik45
Jan 17, 2009 11:34 AM
Jedikid
Sep 29, 2007 09:51 PM
D16Punk
Mar 30, 2007 11:44 PM
NueLyfe
Jul 31, 2006 02:45 AM
