Making a sound
nobody want to mention the fact that tire squeal at high speeds indicates you are going to fast for the turn?
suspension setup or not, if you're squealing tires while cornering, you're at the threshold of the grip for your tires.
what is squealing? the tires or something else?? what tires do you have?
while it's important to have your alignment checked somewhat regularly... your alignment is not going to change or get "messed up" from different wheels or tires.
ORIGINAL: Nail I3unny
did you get your suspension aligned? you probably should everytime you change your wheel/tire setup. something might be rubbing.
thenameisnando
Oct 18, 2011 06:38 PM
inthezoneac
Nov 16, 2009 12:59 PM
atthe123
Jun 6, 2008 10:49 AM
lexdiamonds
Dec 14, 2005 08:19 AM
pimp95civ
Nov 8, 2004 11:25 PM
