My suspension
Old Nov 1, 2007 | 11:03 PM
blackmetal619's Avatar
Default My suspension
is finally complete. It just isnt put on yet, but I have everything laying in my room.
My question is, how hard is it to install a complete polyurethane bushing kit?
I got Koni Yellows, H&R Springs, VSR 16' Black w/ chrome lip, Yokohama Avid H4s 205/45/16, and Skunk2 Front and rear camber kits. I also have the Energy Suspension Master Bushing Set
Another thing. How much would a reasonable price be for all of the previous things installed, including mount and balance, and an alignment.
Old Nov 2, 2007 | 07:17 AM
Everyday Getaway's Avatar
Default RE: My suspension
Mount and balance would be the only thing I'd, "have installed". Will probably cost about $10-15 per wheel for mounting and balancing if you shop around, then it's usually about $50-$80 for an alignment (do the alignment AFTER you've installed everything, otherwise you'll just have to get another one)
Old Nov 2, 2007 | 07:19 AM
My04Civic's Avatar
Administrator
install it yourself FTW!
Old Nov 2, 2007 | 07:31 AM
mxs's Avatar
mxs
ORIGINAL: blackmetal619
it's not HARD, it just takes forever, and is a huge pain in the ***
Here's a DIY
https://www.hondacivicforum.com/m_507169/tm.htm
Old Nov 2, 2007 | 08:07 AM
i really would like to do it myself, but theres so many bushings i dont know where they all go
Old Nov 2, 2007 | 09:26 AM
mxs's Avatar
mxs
There is so much labor involved that it would never be worth it for you to pay a shop to do it...
if you can't identify something, post a picture, and I"ll tell you what it's for
Old Nov 2, 2007 | 11:24 AM
ok thanks, and I almost forgot, for my rims, I need tuner lugs.
I know nothing about them, where can I get them, and what size do I need?
Old Nov 2, 2007 | 01:57 PM
I got my Muteki lugs from here, they're awesome http://jlbmotorsports.com/shop.html
Old Nov 2, 2007 | 02:14 PM
civicexracer's Avatar
all the ES bushings should be in seperate little baggies and have each bushing accounted for and some crappy instructions. for the LCA bushings, expect atleast a full day to do them, day for rear, day for front. possibly have the next day free aswell just incase. the rest of the bushings are easy. the top hat ones u can do when installing ur suspension. endlink bushings are easy. one of the rack&pinion bushings is pretty easy, the other rack&pinion ones i believe u have to take the rack off to install them. the ball joint ones shouldnt be too bad tho i havnt installed em before. try to do as much as u can urself, these things take time and labor costs would be insane...
Old Nov 2, 2007 | 08:33 PM
yea im off on mondays and tuesdays, and a friend that I work with is coming over monday morning to help out. We have about the same experience, hopefully we can get it done. I went to mount and balance my tires myself today, and i completely forgot about valve stems[:@][:@][:@]
civicsam
Aug 16, 2004 02:17 PM
jjhu00
12
Aug 3, 2004 11:19 AM
pilot
Jul 27, 2004 09:36 AM
kourjakian
Jul 21, 2004 04:19 PM
Tornado_sp1
Jul 20, 2004 10:10 PM
