Need help understanding wheels, sprung/unsprung weight
Old Sep 27, 2005 | 05:05 PM
Auto98EX's Avatar
Default Need help understanding wheels, sprung/unsprung weight
OK so I'm buying some HX wheels to replace my 14" steelies and I need some help here understanding how the whole sprung/unsprung weight thing works. I've been reading the weight reduction 101 thread here - https://www.hondacivicforum.com/m_53543/tm.htm
And what I gather from this is that reducing the weight of the drive wheels (front two wheels in my case) has a 70% more positive effect, but reducing the weight of the "dead" rear wheels has no more positive effect than ordinary removal of weight from the chassis. Is that right? So all in all, if I replace my stock steelies (18 lbs per wheel according to this - http://www.superhonda.com/tech/wheel_weights.html - is that right?) and replace them with stock HX's (11.75 lbs per wheel) then I'm reducing the weight of the vehicle by 25 real lbs, but the effect will be the same as reducing the chassis weight by 54 lbs (6.25 x 2 = 12.5, divide that by .30 to account for the rotational thinger = ~42 lbs, then add... err, subtract 12.5 more lbs for the rear wheels for a grand total of 54 lbs)
Sooo... experts jump in. Am I thinking about this the right way?
Old Sep 27, 2005 | 05:14 PM
Street Sniper's Avatar
Default RE: Need help understanding wheels, sprung/unsprung weight
If I understand it and you correctly then that sounds right to me.
Old Sep 28, 2005 | 09:18 PM
amg6975's Avatar
I'm pretty sure it applies to all the wheels, not just the drive wheels. It's basically anything the car has to spin. Rotars, axles, flywheel, clutch, etc.
Old Sep 28, 2005 | 09:43 PM
Chimera02EX's Avatar
The engine doesnt directly spin the rear wheels, if it did it would be AWD not FWD. So hes right, removing weight from the rear wheels is the equivalent of removing weight from the chassis.
Old Sep 28, 2005 | 10:28 PM
amg6975's Avatar
The engine still has to get them spinning. The only way it'd be different is if the front wheels were spinning out. I mean, I could be wrong but it just doesn't make sence that the rear wheels wouldn't be included. They'd still have the same intertial properties as the front ones.
Take this... a motor (the engine) has a gear on the shaft (front wheels) and another one running off that gear (rear wheels,) the motor (engine) still has to spin them both.
Wheels. 12.5 lbs 17" forged Velox Pg5-s.
2.5lbs less per corner of unsprung weight.
Kyokugen lug nuts 1/4lb less per corner.
So 2.75 x 4= 11lbs of unsprung weight, which actually has a greater effect than sprung weight.
Says x4 not x2.
Old Sep 28, 2005 | 11:22 PM
sacicons's Avatar
its more about rotational mass, not sprung or unsprung weight. that has more to do with handling than acceleration. but it does take more power to get the wheel weight spinning than it does to just drag it along (as in the rest of the mass of the car.)
Old Sep 28, 2005 | 11:27 PM
amg6975's Avatar
Yeah... It's all about inertia.
drewwberry
May 14, 2009 08:36 PM
red2000Si
May 20, 2007 04:52 PM
MarcB
EG Swaps
Jan 30, 2007 09:42 AM
nemesis08
Nov 10, 2005 04:01 AM
the_reptilian
Sep 29, 2004 10:53 AM
