Need new rotors..
ok so i need to get new front rotors, and i wanted to get slotted and/or drilled ones, i am on a bit of a budget, and wanted peoples opinion, since i am on a budget should i just stick it out and get stock replacement ones? or does anyone know of a kind that are under $100CAD for the pair for slotted and/or drilled that i could get and have delievered in the next 2 weeks, cause i am going home and will be doing all the work over the holiday's. (canada day and independance day... yeah that is right i get both off[8D])
Since your on a budget, order some Brembo blanks from the internet. I would spend more money on a good set of pads rather than drilled/slotted rotors b/c pads will prolly give you better performance than the drilled/slotted rotors.
hmmm... you are right about the pads... unfortunately i already got some stock ceramic ones. i will check out the rotors first, the reason i wanted rotors is cause i have a caliper sticking and one of my rotors keeps glazing over from the heat, so i need to get that fixed when i get the new brakes installed. if i can't find a set of the brembo blanks then i will just get the stockers for now, and then next year do a full brake overhall, stainless steel braded brake lines, drilled and sloted rotor, and better pads, as well as convert the back to rotors from dums
well i couldnt find anywhere in town that carried Brembo blanks, so i just got a set of NTS rotors from NAPA, they are only Vented but these are only going to be on for a year or so till i redo everything
Booshanky
Sep 3, 2010 03:19 AM
00IntegraLS
17
Jan 20, 2008 04:50 AM
theredsuit
18
Aug 9, 2007 04:48 PM
civic_x
Jun 12, 2006 09:05 PM
mrblackhp
15
Jul 20, 2005 12:59 AM
