New rims...need speedometer adjustment?
Old Jan 14, 2009 | 04:58 PM
Jimbo&2000SI's Avatar
Default New rims...need speedometer adjustment?
I bought some 17in rims for my civic to replace stock 15's. I've heard that my speedometer may read mph wrong. Is this true? If it is, how bad could it be and how could I adjust it?
Old Jan 14, 2009 | 05:53 PM
Kommando's Avatar
A change in rim diameter doesn't throw your speedo/odo reading off. A change in tire diameter does though.
Make sure your tires are the correct diameter for your car. What year Civic and what was the stock tire size?
Old Jan 14, 2009 | 05:58 PM
2000 Civic Si with 195/55R15.
Old Jan 14, 2009 | 06:47 PM
it won't throw your speedo off much. probably less than 5mph. IMO not worth re aligning the speedo. use this tire size calculator to see whats the MPH difference and keep that in consideration when you are driving http://www.1010tires.com/TireSizeCalculator.asp
Old Jan 14, 2009 | 07:03 PM
Kommando's Avatar
'00 Civic stock tires are about 23.5" in diameter. 205/40-17s (about 23.5" diameter) will fit a moderately dropped '00 Civic with rims of the proper width and offset.
Old Jan 15, 2009 | 04:46 PM
Ok thanks.
Old Jan 15, 2009 | 06:10 PM
yea, the above info is correct
you live in Titusville too? small world
did you just buy your civic? and is it blue?
if so, i saw you at auto zone. lol. i was parked next to you.
at least i think it was you.
Old Jan 15, 2009 | 06:22 PM
No way man really?
Naw I did just buy my Si but it's red not blue.
Do you go to THS?
Old Jan 15, 2009 | 06:25 PM
No way man really?
Do you go to THS?
Hmm I haven't seen a red Si around yet. Maybe i'll run into you sometime.
I go to BCC, I graduated from AHS last year.
Old Jan 15, 2009 | 06:28 PM
another honda to look out for around town is a 92-95 white civic CX hatchback with a black or CF hood and tailgate. The guy works at Honda and he has a turbo LS swap, and he's building another LS in his house. That guy's Civic is clean as hell.
http://inlineperformance.org/id24.html
are you selling the 15's? i'm totally interested.
