new springs
so im thinking about putting in some eibach springs in my 2002 civic lx. i know i need a camber kit but which ones should i be looking for. i also plan to add in new subs in my trunk (if that matters)
You don't NEED a camber kit with an Eibach kit. And which kit were you looking at? The Sportline or the Pro kit? The main thing is getting an alignment right after the car is lowered. Subs won't really compress the springs that much if you're running higher spring rate than stock.
no need for camber kit....just get an alignment and your good! Youre not gona be low at all any way with an eibach kit.
i've seen the eibach kits or just the springs. do i need the kit or can i just get the springs
if you want you can just get springs for your stock shocks...
