new springs. should i change anything else?
Old Mar 25, 2008 | 05:48 PM
gokudo_sama's Avatar
Default new springs. should i change anything else?
I am getting new Tien Lowering springs soon and I am trying to find out whether or not I should change the struts and sway bars. Also, what is the difference between the two of those. Also, with the new springs should I change anything else if you suggest me changing one of those two things. Thanks.
Old Mar 25, 2008 | 05:53 PM
civicexracer's Avatar
Default RE: new springs. should i change anything else?
what year/model civic? when lowering a car, its usually good to upgrade the shocks. ur OEM shocks will wear quicker and its justa lot easier to do the shocks and springs all at once insted of having to take apart the suspension a couple times.
Old Mar 25, 2008 | 07:29 PM
rin's Avatar
rin
Hard to answer your question without car specifications. Yes, I recommend you buy struts and sway bar. Both are necessary to increase your cars ability to corner. I would also recommend you change the bushings. Braking (if not already) should come next.
Old Mar 26, 2008 | 03:32 AM
Yeah sorry. I have a 05 Civic ex. What is the difference between the struts and sway bar. And as far as new shocks go any suggesionts? should i try and find some tien once since that prob what im going to do for springs? Also, what are the bushing. Sorry, i'm not a whole noob but i am kinda new to the whole things as far as suspension goes. thanks.
inthezoneac
14
Apr 12, 2008 08:24 AM
tallyimports
Apr 15, 2006 07:29 PM
disturbed2277
Jan 26, 2006 07:26 PM
pimpingitup239
13
Jul 7, 2005 07:48 AM
315 Customs
Jun 20, 2005 11:16 AM
