New wheels size question
Im about to order some Drag DR16s this next week. My car had 17s on it when I bought it last week and they are rubbing on about every turn. So im stuck between getting 15s or 16s. I would like 16s but didnt know what the difference would be with tires between the 16s and 17s? I want to make sure im not going to have any rub. Should I get 15s or 16s? Its for a 2000 Black Hatch.
OK. Got some 16s. Car had 17s that rubbed when I got it. Think I should go with 205/40 or 205/45 with the 16s? Cars lowered on H&R springs.
205/40
205/45 is gonna rub probably |
205/40 if you are running 16s. If the offset is good you should not have to worry with a 205/35 but you woudl have to worry less with 205/40s. It gives you you a bit more room and not that great a reduction in ride quality. The difference is only 6mm but that could be a difference. more importantly, HOW much of a drop do you have and what is the offset on the rims you are running?
The wheels are +40 I think. Rota Circuit 8s. Guess Ill go with 205/40 or 195/40 just to be safe. Ive never had 16s so I dont know what to run. 195 or 205?
^205/40
on a hatch get 205/40 r16
the coupes use a slightly bigger wheel so they run 205/45 r 16 |
I was wondering if coupes have bigger wheel wells or what. My friends 2000 Si has 16s with 205/45/16 and doesnt rub. But we have the same drop, same rim offset, and they rubbed on my hatch. Weird. Tried them out yesterday.
(Post 630497)
(Post 630497)
coupes and sedans run either a 185/65 r14 or 195/55 r15 depending on factory rim rize. and the hatches run either a 175/70 r13 or 185/60 r14 depending on rim size. so for coupes and sedans the recommended tire size on 16s is 205/45 r16, while the hatches is 205/40 r16. |
